Hey guys, im getting a substantial knocking noise on my front/left when I release throttle and car begins decelarating. Im thinking its possibly a driveshaft/diff/possibly gearbox? kinda area...
Bit worried as I have only just bought her.
Are there any known or common problems that the polo 9n TDI 100 sport suffers with?
Also does the polo GT have the same gearbox/drivetrain setup as the 100?
Any advice will be greatly appreciated.
Regards
YOGi
Problem, Drivetrain!
hey, iv got a GT, and had a similar problem, just in nutural, or a low gear nt reving, you can hear a slight rubbing noise (as if the pad was brussing against the disc), but once the car has warmed up this seams to go away, took it down to the local vw, and they fitted a wheel spacer, but the noise is still there, but lately, a few people with the same engine iv been speaking to, have said the same thing :-S,
yorks GT TDI
- Sponsor
Drivetrain is completely standard.
I fitted some monty 2's on saturday, m thinking there could be an issue with the larger diameter tyre... tyres are straight off the golf the montys come with.
Could this extra strain put too muich pressure on he car?
Smaller profile tyres needed once problem is fixed?
What profile etc you using?YOGi wrote:Drivetrain is completely standard.
I have 205/45 on my Monty 2's with no issues (touch wood)
