Removing headlights?
AKs_SlickPolo
Post by AKs_SlickPolo »
Just wondering, has anyone ever attempted to remove their headlights?
I need to do so and was wondering that do you only have to remove the front bumper, and simply undo the bolts you see for the headlights and prise the unit out?
My reason for asking is because they look ever so close to the wing's, and the levelling motors are probably sitting more inwards, so would i also need to remove the wings?
Any advice or help to removing these would be great! thanks :D
dino
Sponsor
Post by dino »
Take the bumper off, few screws hold the headlight unit in - pull it out....simple-ish!
The levelling motors are actually in headlight unit.
AKs_SlickPolo
Cheers Dino 8) , so these levelling motors, can they be removed easily from the original headlights and applied to another headlight unit?
dino
Sponsor
Post by dino »
no idea, never had a look at the levellers - just know where they are
vwclub.gr
Post by vwclub.gr »
If your headllights are "Valeo" then removing the leveling motors is very easy and you don't have to remove the headlights. If not, then these motors can't be taken off
AKs_SlickPolo
VWclub.gr - My headlight's are the Valeo ones. I'm fitting the same headlights as you - the FK smoked ones!
Sorry to sound stupid but I dont know what the levelling motor looks like. Can you describe where it would be? or can it be seen in the picture of my lights below? as I need to remove and fit it to the FK ones.
dino
Sponsor
Post by dino »
No it can't be seen from the front - look behind the caps on the rear of the headlight unit. it's under one of them
AKs_SlickPolo
oh right :lol: Ill have a look down there. Cheers
vwclub.gr
Post by vwclub.gr »
There are 3 caps. The 2 of them are for changing the bulbs. The other one is for the motor. It is the centre one. It is very easy to remove it and fit it in your new headlights.
AKs_SlickPolo
thanks mate :D , hopefully I can fit them now with no problems! (well once I can find a day when its not raining :x )
vwclub.gr
Post by vwclub.gr »
Really? It has been over 1 month here that it hasn't rained and the temperature is over 35 :!:
AKs_SlickPolo
Well i finally got the time to fit the lights yesterday. Really like them :D Just not so happy about how they fit.
They seem to sit too far in at the bottom and you can see a gap. Ive spent about 1 hour trying to adjust them perfectly in proportion to the panels. However at the bottom of the bumper, a gap is visible. I think its even with the standard lights but cant remember, maybe its a bit amplified as they show up more than the standard ones on a silver car. Does anyone else have this sort of gap?
its where the bottom part of the bumper (of the larger light) meets the wing!
vwclub.gr
Post by vwclub.gr »
I have the same problem but I thought it was because of my bumper which has been changed
AKs_SlickPolo
Thanks for the reply mate...
Hmm, guess it may just be the FK lights then. Ill get some pics up of it. Ive got the genuine factory bumper :? and i still have it.
I think I will try using thick washer's between the bottom bolts and the lamp. This way the headlight unit at the bottom will raise slightly so that there is no gap :idea:
rob-g
Post by rob-g »
Mine has a bit of a gap with standard lights and bumper, you can make it out in these pics:
http://i17.photobucket.com/albums/b100/ ... car033.jpg
http://i17.photobucket.com/albums/b100/ ... car014.jpg
were the new lights easy to fit? is it just a straight swap?
