I'm sure you can't actually remove the mirror switch on it's own, you'll need to remove the door panel also. First, remove the door lock operating knob (should simply unscrew) and then you prise out the handle centre panel (where your big arrow on right is pointing to) using a screwdriver (with cloth behind so as not to scratch anything) then remove the two screws that you will then see. Then there is a screw at the front of the trim panel (on top left hand side out of shot as per your pic); you then have to prise out the window switch (carefully) and disconnect wiring plugs, noting where all the connections fit. Then carefully release the door panel studs and ease the panel away from the door. Why do you want to do this? To get behind the panel?
Hope this helps anyway!
if your on about the outer edge of the door handle, the bit left when you remove the grab handle cover and control switch... then you cannot remove this without first removing the door card...
reason being: its screwed to the door card from behind
on my 1.0 they can be both prised off trust me, no screws holding either of the bits highlighted that you want off.
i know because i colour-coded both bits, maybe its different for other models?
im trying to get that bit off as its all scratched and im hoping to rub it down and spray it gloss black as it looks really good saw it done on a gti at vwfestival!
so do i have to take the door cards off?
also does anybody kno how to get this off? so i can spray it black like the gti?
