My G40 progress thread - 10/01/07 updates, page 9
Ok! Some more progress today, thought I'd try out a bit of budget sound deadening for the doors
I'd read on E38 some time about a guy using flashing tape from B&Q doing the job. And sure enough it does, kanny cheap too
I'm sure it's not as effective as Dynamat but just one skin layer of this stuff on both doorcards has already made a difference to road noise inside!
I love door condom
This is the shizzle
Doorcard's DOB
Application
Gayboy
Just like the real shiznit
Goof about after a rattle hunt in the boot
I love door condom
This is the shizzle
Doorcard's DOB
Application
Gayboy
Some more progress
I've been thinking for a while where the hell I could mount my boost and oil pressure gauges. I didn't want them to stand out like a sore thumb and I needed it to look OEM!
So after changing over my dashboard, and finally getting a new glovebox doorlid I had some spare plastic to try out my idea!
Seperated the old glovebox door, so I was left with the outer skin. Used my original dashboard out of the car for something to work from
Started off with a carboard template
Followed by cutting up the glovebox working from the carboard template
We're left with the basic shape!
A bit more fine trimming and we have the final product
The hole at the bottom, that was once the glovebox lock, will soon house a lighting unit with red LED. It'll illuminate the centre console/gear knob - just like the Mk5 Golf GTi does from the ceiling.
What's left to do is secure the bottom end, then get some of those offset angle pods/rings for the gauges so they're pointed up towards the driver and get the pods in!
Will update again when there's more progress!
More on the gauges mount today
Got it all fitted very nicely into my car
Got some temporary "space filler" gauges out of an Audi I had lying about in there for now.
But those are basically exactly how they will look as I will be fitting the "thru dia lighting" VDO boost and oil pressure gauges when I get them - very OEM looking. Also, I'm not sure if I will bother angling them up towards me as I can read them fine
Still to do the light in the gap underneath, but that can be easily done another time
Also, because I need to charge batteries for cameras n that on the move I have moved the cigarette lighter down to the side of the centre console
Might tweak the curve a little more sometime too, but..
Voila!
Voila!
James14100
