i was speaking with another polo owner and he thought that its not possible to remove the gearbox with the engine still in??
can i leave the engine in or no?
any tips/advice ...its a 4speed to 5 speed swap on a 88 1300
mk2 gearbox removal?
steveo3002
steveo3002
oh well almost done it now...spent 6hrs today and all ive got left is to bolt up the driveshafts and gearlinkage
things id mention to anyone thinking of doing it....get a helper, i struggled for ages and prob wasted 1.5hrs trying to lift it up on my own....then i got my dad to lift it on a rope while i pushed it up, went in on seconds
and i didnt realise the coolant hose would need to come off to access the top front bolt...so thats a chore
the 160k orig clutch still looks plent good enough
but i replaced it anyway
looking forward to 5 speed motoring..
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
you did it in one day, first time, with no help? f**king legend, mate!
mine was a complete pain in the plums, took like 3 days with plenty of advice and guidance (and trips to get more socket bits from halfords!) - and that was on the mk3 which is supposedly more built for the 5spd (& should therefore be easier to get the 4 out of)
enjoy! just don't try to get too much speed (hi or lo) out of 5th if its an 8P and you're a 1.0, as it will actually hurt the economy (quieter and easier on the engine tho).. 40 to 65 is best... v frugal then
steveo3002
Tahrey1043
hm, perhaps you had a 3+E or something... or one of the wierd boxes beforehand. then again maybe you've got a diesel or G40 box (really tall ratios)... do you know it's origin/code at all? and how fast will it go in 1st before hitting the limiter (if you have one?)
i could try to ID it for you if you can estimate the mph/1000 figs for each gear
still if it doesnt like it below 40 that's a nice cruising box you have there
i was thinking more like 35 but decided to be conservative for the recco
steveo3002
Tahrey1043
£10? you lucky bugger. I think i ended up paying about £70 in the end, and that's because the guy selling it to me was a diamond. Just hope it's better than the one fitted to my brother's escort (SILLY BOY!) when he bought it; 100 miles later and he's lost third gear. £200 to sort. Ouch.
Fraid i can't offer much more advice, p'raps your original one came with a motorsports type 4 speed but the other was a bogstandard 5-speed (with a different final drive to boot)... or the other way round, even... though i can't see why it'd be very slow under 40 in top if it's a GT-style box (1st is the same, 5th is like 4th-and-a-half, and 2nd-3rd-4th are compressed down to give lower/tighter ratios) unless you were lacking torque at the low end. (still around 2100rpm vs maybe 2300-2400 previously - 8P giving a significantly lower 1900)
