olop_chris
Sponsor
Posts: 2131 Joined: Wed Feb 01, 2006 11:15 pm
Post
by olop_chris » Thu Nov 02, 2006 1:29 pm
They've arrived, i've not seen them yet though as they're at my girlfriends house for now....
Has anyone had experience with camber adjusting bolts? and if so...is it an easy enough job for me to have a crack at on my own? Also will i need to get the tracking re-done after changing the degrees on the camber itself?
Thanks, Chris
jezmk4
Posts: 275 Joined: Sun Feb 29, 2004 7:24 pm
Post
by jezmk4 » Thu Nov 02, 2006 10:45 pm
what the hell is a "camber adjusting bolt" for a polo 6n/2 ?
rear camber isnt adustable, and front camber is adjustable by how the suspension is attached?
olop_chris
Sponsor
Post
by olop_chris » Thu Nov 02, 2006 11:07 pm
jezmk4
Post
by jezmk4 » Fri Nov 03, 2006 1:21 am
You do know
that you just set the camber by how you tighten the bolts on the slotted hole on the standard strut?
olop_chris
Sponsor
Post
by olop_chris » Fri Nov 03, 2006 1:27 am
Yeah, but apparently it can only be done by a tiny certain amount?
Ill see what these bolts do anyways
jezmk4
Post
by jezmk4 » Fri Nov 03, 2006 1:44 am
the bolts do something, that your standard setup can do already..
if you need more adjustment from you current setup, you can use thinner bolts for more movement
you should easily be able to dial in 2 degrees with standard setup
which is more than enough for track use, and enough to ensure that the inside of your tyres will get eaten away faster
vdubit
Posts: 619 Joined: Sun May 22, 2005 12:53 pm
Post
by vdubit » Fri Nov 03, 2006 9:59 am
Cos our cars are wound down so far you cant adjust it anywhere near enough using the standard holes in the shocks. I'm just gonna drill the holes a bit longer. Tis cheaper!
jezmk4
Post
by jezmk4 » Fri Nov 03, 2006 5:07 pm
vdubit wrote: Cos our cars are wound down so far you cant adjust it anywhere near enough using the standard holes in the shocks.
well my camber is fine, and cant be adjusted perfectly well and there is no way your car is as low
the camber barely changes as the car gets lower, and as it does, the negative increases. still plenty of adjustment
Si_GTi
Moderator
Posts: 5020 Joined: Thu Apr 08, 2004 1:14 pm
Post
by Si_GTi » Tue Nov 21, 2006 4:56 pm
For the sake of £30 I have just bought a set of these bolts for my own GTi in readiness for the suspension swap I have scheduled.
ticki
Sponsor
Posts: 720 Joined: Thu Sep 28, 2006 12:34 pm
Post
by ticki » Tue Nov 21, 2006 8:10 pm
Have you decided what coil overs your going for? How much did they cost, and where did you get them from?
cheers
Si_GTi
Moderator
Post
by Si_GTi » Wed Nov 22, 2006 1:14 am
ticki wrote: Have you decided what coil overs your going for? How much did they cost, and where did you get them from?
cheers
FK konigsport silverline x - nearly £400 + cost of new top mounts + H&R bolts + fitting - bought second-hand from Saj at Gwent VW
