Search Informations about suspension and exhaust
Spiderdimit
Post by Spiderdimit »
Now , I would like to drop the car , if somebody can give me some informations best choice for a complete suspension ?
I'd like to have informations about the exhaust too , I would like to change it to have more power and a little more noise, what do you think about it ?
Bye
Dimitri
mk4 glx 1.6
Re: Search Informations about suspension and exhaust
Post by mk4 glx 1.6 »
Spiderdimit wrote:if somebody can give me some informations best choice for a complete suspension ?
That is such a subjective question. What are your requirements e.g comfort or looks, very low or subtle, asjustable height? adjustable damping? coilovers or springs/shocks.......the possibilities go on.
Spiderdimit
I would like to keep some comfort because it's not a racing car and I use it nearly everyday.
But when I drive fastly I would like the car is more accurate in the corner.
It's also for the look because I find it to high but I don't want to drop it too much .
I think 40mm is enough :?: after that it 's difficul too drive the car on belgian road with all the slowdown they put :roll:
Adjustable is better but it's also more expensive and I don't want to spend too much money.
What do you think about the mark " KW " :?:
mk4 glx 1.6
Pretty much the same requirments as me then.
If you are happy with a fixed drop of 40mm, I would obviously suggest a matched shock and spring set.
KW are very good quality. Obviously not cheap, but in my opinion, you do get what you pay for.
I would spend the most amount you can on the dampers, afterall these detemine the control of the car and how the spring reacts.
Are you aware KW do a matched springs and shock set (-40mm) for the 6n2 gti? Part number is 20080063, RRP is 459 Euro's. Weitec also do a simlar kit (manufactured by KW), which is cheaper. I assume the components used are of slightly less quality.
Spiderdimit
Suspension kit
Thanks for this information.
I'm gonna to the "Essen motorshow" next friday(08/12) and I will compare the products and the price I 'm able to have :roll:
mk4 glx 1.6
Re: Suspension kit
Spiderdimit wrote:Thanks for this information.
No Problem, there are many more options from other manufacturers too.
By the way, I have heard that KW will be releasing/promoting their new range of "Street Comfort" coilovers at the show. If you happen to find out any further info or pricing regarding these, please report back?
http://www.kwsuspensions.de/uk/30_Produ ... /index.php
KW UK have said no further details will be released about the product until after the show :( .
