Results after running vag.com
thedees1
Sponsor
Location: edinburgh/livingston, drives: polo gti red 5dr
Post by thedees1 »
here are the results listed below,a couple of faults, not sure what they all mean, i knew about the lambda sensor needing replaced but not sure about the other ones, if anyone could help id be gratefull
VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ********** VW*********
2 Faults Found:
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
16554 - Fuel Trim: Malfunction: Bank 1
P0170 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
1 Fault Found:
01130 - ABS Operation
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 04001
Shop #: WSC 00788
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6N0 920 904 K
Component: KOMBIINSTRUMENT BOO V09
Coding: 00444
Shop #: WSC 00799
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00788
Address 25: Immobilizer
Controller: 6X0 953 257
Component: IMMO 0007
Coding: 00001
Shop #: WSC 00000
WVWZ*********** VW**************
Address 45: Inter. Monitor
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46: Central Conv.
Controller: 6N0 959 799 B
Component: 7E Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00788
1 Fault Found:
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
Address 55: Xenon Range
Controller: 6N0 941 273
Component: Leuchtweiteregelung 0001
Coding: 00002
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
mk4 glx 1.6
Post by mk4 glx 1.6 »
I assume that is your chassis number listed in a couple of details - I would edit that out sharpish !!
1 GTI
VAG-COM
Post by 1 GTI »
I've got VAG-COM myself mate. Instruments - You need a new temperature sensor, Not that expensive and easy to do. Located below your HT leads, it's a small green casing.
Central conveinence - Loose connection between your alarm horn or the alarm horn it's self has broken.
