well its a buggery the car wont work. either im lazy or your mad, i wouldnt take my wheels of to clean em. after all whos gonna see the back of the wheels when ur driving? or parked? unless u going into a "cleanest car" competition. i spend abotu half an hour cleaning my car every now and then and thats good enough for me....... but there again i am busy most of the time........ its called working......... u should try it some time;)
yup the highsports on my mk4 are a joke, rust so easily. really if you want to go for fk's you NEED te silverline's!!! or just save up the extra for kw's. . . . .
bit gutting after all that hard work that the car won't start! was admiring how clean the wheels are when i got home last night
here's another pic of it for you
Mouse_GTI wrote:There were a lot of stubborn tar marks which took a long time to get rid of......................Tried using Autoglym Intensive Tar Remover with the sponge but it was no good. Ended up using white spirit to get rid of it but later managed to use the Autoglym stuff effectively.
Did you try using a clay bar on the tar spots? This is usually an effective methods of removing them, unless they are particularly thick.
Wheels look good. I always clean, seal and wax the inside's of mine whenever I take the wheels off for any particular reason.
Whilst you had the wheels off, I would of cleaned the threads of your coilovers and applied more copper grease to them.
Tried Sonus Green clay on them but it was useless. Just worked in the Autoglym stuff, got most of it off, rinsed it, then went over the last few bits then rinsed again
the wheels r blingin mate, good job! i wanna wash inside of my wheels too as well as the callipers but i wouldn't go as far as to clean the arches! like others have said, they just meant to be dirty! i see your brake calliper paint has cracked big time, happened to mine too... so annoying! thinkin i might get them powder coated for more hardwearing finish... do it when i do the G60 brake upgrade! by the way, what tyre gel did u use? wouldn't it have been a good idea washing the rest of the car b4 putting the wheels back on otheriwise the muck from the car just gonna get on the wheels?
Apparently it's best to do the wheels first. Could always covered them with a black bag. I used Blackfire Long Lasting tyre gel, it's ment to be good stuff and last about a month. I'll also get my callipers sorted if I get the G60 brake upgrade
I hate tar so much. It's the reason I spend so long on the car, because I have so much tar and it takes so long to take off. Plus one of my mates say I have "legendary attention to detail"
yea in the summer it takes me about 25-30 hours altogether to get the car looking how i want it, wash, claybar, polish one day, then next day it'll be wash, extra gloss protection, wax, then next day it'll be like wheels, door frames, engine bay etc
