Switched Power
Switched Power
Where have people got a feed for switched power from? I am not to keen on piggy backing the headunit for other devices.
willriseley
Running it off the battery wont turn the device off when the ignition is off though.
In my case i use a Nokia Bluetooth Hands Free kit and my phones stays connected to the car when im in the house making calls a bit awkward lol
I never connected the switched power lead to anything when i installed the kit so need to find somewhere to fix it too other than the head unit which i already use for my amp.
ModifiedMadness
- Sponsor
But then its no different from having the off switch on the stereo...
I would get a test lamp or multimeter and test which terminal(s) on the fusebox illuminate it with the ignition on and dont with it off.
It will be the power for things like heated rear screen, headlights etc etc, all stuff that is switched with the ignition. Then run another power cable from the fusebox to the stereo.
I'm going to do the same once i have got my new stereo.
polo power
polo power
Re: Switched Power
when you say piggy back do you mean to have 2 wires joined together?knaps wrote:Where have people got a feed for switched power from? I am not to keen on piggy backing the headunit for other devices.
