Those of you with a BMC filter
D-Dub
Post by D-Dub »
How did you remove the piece of plastic that connects the original vw air feed? I want to remove it so i can have my own going into the wing? Pics and step by step would be perfection :D
Mouse_GTI
Post by Mouse_GTI »
Me too. I've ordered my new cold air feed and will finally be getting it fitted next week.
Need to know where the bolts come out of as I will be putting it back to standard if I ever sell the car
LiverpoloGTi
Post by LiverpoloGTi »
The only bolt I had to undo to get the OE airfeed out was under the power steering fluid reservoir. Once this was unclipped the bolt was accessible and the feed came out easy.
Some good pics in this guide.
Si_GTi
Moderator
Post by Si_GTi »
LiverpoloGTi wrote:The only bolt I had to undo to get the OE airfeed out was under the power steering fluid reservoir. Once this was unclipped the bolt was accessible and the feed came out easy.
Spot on. Get that bolt out and the original plastic air feed comes right out :D
sally_healey
Post by sally_healey »
That's what I did & then fumbled around for a while getting the new pipe into the oval (ish) hole where the OE airfeed used to be, got there in the end though :D
Mouse_GTI
Post by Mouse_GTI »
Is the OE air feed also a 69mm diameter approx?
sally_healey
Yeah roughly but it's squished :?
D-Dub
Post by D-Dub »
Got mine off tonight. Piece of cake :D Just gotta wait now for my dad to make me a stainless pipe 8)
Tigz
Post by Tigz »
Take your car to VW for a cam belt replacment.
If its any thing like my local dealership, they'll not bother refitting it :x
