Coil packs, and wheels Qs
jokjok11
Post by jokjok11 »
Hey all! I'm new to this forum, and can i say this website is 10/10! brilliant!
I have a 2003 1.2 polo, and bought it 2nd hand. The car is brilliant, however experiencing a few problems!
In the past few months, I have had problems with the coil packs (I believe?) and went to the VW dealers to fix this. VW being great, fixed this free of charge :D and this happened on 2 seperate occasions. I think the 3rd Coil pack has failed today, as the warning lights have come up again (engine light on dashboard) They said that this was a common problem and they have made new coil packs which don't have this problem. I'm not complaining, as they also wash my car after the job :D
Does anyone with this car have the same problems i've had?
Also I am wanting to buy some new alloys, Sorry about the previous posts about alloy fittings, but i'm getting confused with all these Settings (easily confused sorry :S lol) can someone double check if this fitting will fit my car?
Offset: 42
Studs: 5
Tyre Width: 205
Aspect Ratio: 55
Load Index: 91
Would greatly appreciate all your help, thanks :)
keenan27
Post by keenan27 »
Welcome To the forum.
Replie to your wheels query.
i drive the same polo and i have recently put aftermarket wheels on, which are very similar, 42 offset, 205, although mines are 45. just curious, what size are you planning on buyin, i am currently sitting on 17" with a 30mm drop with no rubbing.
jokjok11
Post by jokjok11 »
I am thinkin of 16 inch, but maybe 17inch ones... however, i am worrried of the tyres rubbing on the arch if i have 17 inch? Especially when i have stock suspension etc? Do you think that would be a problem?
Also, does the stud diameter HAVE to be 5x100? I have seen some alloys but are stud diameter 114. Will this not fit? Thanks Dan
AKs_SlickPolo
Post by AKs_SlickPolo »
Welcome to the forum 8)
Coilpacks - There is a modified coilpack - as long as all are replaced with new versions this should not be a problem (..theres loads of posts on coilpacks, just use the search function mate)
Wheels - only 5x100 will fit. Shouldnt have problems with 17s on stock suspension (unless you plan on taking humps at silly speeds) But tyre ratio must be Width: 205 Aspect Ratio: 40
paulnorbury
Post by paulnorbury »
sorry about this history lesson but going back to the 1950s my dad had problems with ignition coils , they would burn out ,there was only one , it did all 4 cyls.so the manufacturers filled them with oil to keep them cool and they were as far away from the engine as posible as heat destroyes them . have you got this you inexperienced university so called engineers at vw. paul motor engineer . blackpool.
paulnorbury
