Hi Norton, and welcome to the forum.norton wrote:Will 17" 205/40/17 with a 40mm spring reduction really be ok on my 1.4
se mpi , got to mail order the wheels and cant send them back.
I dont want to carry out any mods if i can help it.
Cheers ........ Norton.
The size you're after is not a 'safe bet' by any means. Whether you end up with rubbing wheels is a matter of the ET and/or the type of tyre you select. Some tyres have a tendency to be wider than others, even if they're the same size. Also, some tyres are more rounded on the corners, giving you just a bit higher margin. Coilovers help too, because they tend to be a lot more solid than regular springs and dampers.
I think Harry is one of the few that has had zero problems with his 17's.
Let us know how you get on.
