puuting amp power cable to battery ??? HELP
jason11
Post by jason11 »
rite guys, i want to wire up my amp n sub but im having a problem gettin the power cable through to the battery !!
can u guys give me some ways of doing it, n pics so i get the jist of it lol !!
cheers guys
jason11
Nottspolo
Post by Nottspolo »
Hey i only put my amp and sub on sunday, i wired mine trough the hole where the rear wash pipe goes through the bulk head (you can follow this from the washer bottle next to battery) I then followed it all the way to the back underneath N/S sill trim removed. If you would like pics i am sure i could help.
jason11
Post by jason11 »
yer if u dont mind posting up sum pics plz mate, i can tfigure out were to go through, ders meant to be a grommet u take out n found some but cant seem to find where the power cable actually goes
cheers jason11
Danny G
Post by Danny G »
I did mine through a grommet thats located behind the passenger side dash. If you get ur hands up and feel about ul find it! its easier if you get some wire, form a looped end and access it from the engine side... Just push the wire through, find it in the car, wrap the amp cable round the draw wire and the pull it back through into the engine bay... Theres the main power cable coming from the battery passing through at this location. :D
warrmr
Post by warrmr »
the battery connection
closeup of the hole for the wire. ( it will easly fit 4awg through there as i have upgraded.)
amp mounted and relocated boot light.
mmh
Re: puuting amp power cable to battery ??? HELP
Post by mmh »
jason11 wrote:rite guys, i want to wire up my amp n sub but im having a problem gettin the power cable through to the battery !!
cheers guys
jason11
Jason, check the DIY guides section here's the link to the guide to do this!
http://www.tigerstyle.co.uk/poloforum/v ... php?t=5097
Dan1989
Post by Dan1989 »
hey
with the little gromet does it matter if its not there?
as when i put my power cable through it sort of didnt wana go back so it went :lol:
