wheels...concerned
M7
wheels...concerned
Post by M7 »
Im going to get some new wheels in a different PCD and going to run a 20mm adapter.
the rim offset is 34 and with a 20mm spacer is this going to be sticking out too much from the arch?
so its going to be like having a et54 on my wheels, correct?
carmadaaron
Re: wheels...concerned
Post by carmadaaron »
M7 wrote:Im going to get some new wheels in a different PCD and going to run a 20mm adapter.
ET14 I would think.
dino
Sponsor
Post by dino »
i wish i could help but i wheely don't know......
.....TAXI
ceedubya
Post by ceedubya »
ET14 I would think.
Ditto :wink:
ya might get away with that offset depending on wheel / tyre size
AKs_SlickPolo
Post by AKs_SlickPolo »
Whats the width of the wheel and tyre size you intend to use?
ET14 at the rear will be okay as long as you don't go very low.
At the front your probably cutting it a bit fine! :shock:
david burton
Post by david burton »
it all depends on the width of those wheels, put up some sizes :)
AKs_SlickPolo
If its 8J you will most likely have problems in the front even if your not so low and have stretched tyres - arch modifications will be needed!
Anything below and you may just be okay. Back would be fine.
gary87
Post by gary87 »
im gna be running 16x7J pretty soon with coilovers, will I need much arch work if any at all?
M7
Post by M7 »
its an 8x16 rim
running 20mm spacer/adapters
going on 195/45 or 205/40 rubber.
will i be ok?
