[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 aerial base - UK-POLOS.NET - THE VW Polo Forum
you don't have to remove the complete headliner, just the plastic piece at the very back. you can then pull the headliner downwards and reach the antenna base. make sure you wear a long sleeve top or your arms will itch for days because of the headliner material
