youd be surprised how hot a wire can get in a matter of seconds
if you wanna see then get an old car battery thats charged and hold a piece of speaker wire in some pliers and touch both terminls at once
i found this out when i was about 14 and read the the lead in a pencil is a semi conducter and can be used as a fixed value resistor if urgent so i cut the wood of a pencil and held it accross the terminals of a house alarm, backup, battery. after about 2 sec it was white with heat
so never under estimate the things that can go wrong
i accept no liability for any injuries (to you, your property, your cat/dog/goldfist/hamster/etc) caused by the text within this post and any experimentation is at your own risk. BE WARNED!!
