keep up the good work.
Can I get an induction kit for mk3 Match?
patrick86c
hardhitter
- Moderator
the gt was only in the uk sold with an hydraulic head mh 55 hp engine .
ther is an option to het more umph out of that engine .if you flatten the topsite from the body engine for about 2mm ,evenso get 2 mm from the top from the pistons ,deepen the valve seats in the piston for 1 mm.
flatten the head for 0,3 mm .take a 3f camshaft .tahke a pierburg2e3 carb from a golf mk2 1.8(straight swap).the intake and cylinderhead ports should be grinded .let it run on the original ignition with fuel ron 98.should give around a 80 horsies with standard stuff .imagine with a faster cam what it can do
patrick86c
Gilex
- Drives: 6R 1.4 (2010) & 6R 1.2 TSI (2012)
Well I can´t stay behind:
Basic AAV engine with golf 1,8l throttlebody (motorcode RP) and intake from a GK coded polo engine, grinded for better flow. and the allready mentioned induction kit.
Exhaust is a homemade midpipe and only a Remus backbox
Still to come 3f camshaft and G40 outlet manifold and a G40 downpipe with empty cat. After all mod´s are done it´s time to modify the ECU for the last bit of extra power.
patrick86c
hardhitter
- Moderator
patrick86c
