bbs replica rims
bbs replica rims
http://cgi.ebay.co.uk/15-BBS-VW-GOLF-PO ... dZViewItem
anybody seen these up close - good preice for wheels and tyres, and easier than a refurb, just depends if they look OK in the metal so to speak...
shantybeater
I dont think they'd look great up close. You can see the bolts look a little small (they serve no purpose cos they are fake splitties) and the you can also see the gap where the real outer would join the centre looks a bit fakey. I imagine these are 1 peice rims. Bear in mind you are looking a at small photos, in real life the poor quality bits would look even worse.
There's many genuine second hand RXII's floating about on ebay. I'd buy the real thing, or if you can't be bothered refurbing then go for a totally different wheel.
Everyone that owns a polo GTi would be able to spot fake RXII's a mile off
mk4 glx 1.6
These are the above replica wheels on a 6n2 gti:
Also available here.
I think the owners name was Richard Harper, or my memory may not serve me so well? All I do remember is that they definately fit with 280mm disks.
shantybeater
garnier wrote:Masking bits off just leaves a messy egde, I wouldn't do it with my rims.
I meant if a professional did them, not a kerbside motors job
dont want shell out for steelies, then pay for tyres to be swapped, then repeat the process again a few weeks later, waste of money. Id rather pick up a s**t set of anything, sit the car on those for a couple of weeks, send the wheels away to be sorted whilst I take a few weeks in the sun somewhere hot - then come back to a shiny set of refurbed rims
one thing to look out for is on the fake bolts, as time goes by the finish on them will start to crack.
with the originals you can remove the bolts and just replace em with new ones, however with the replicas expect the paint/finish on the bolts to start cracking off as time passes by.
they do look good new but i dont think they can stand the test of time.
When I bought my gti it came with two reals and two fakes. If you put them next to each other the only visable differance i the centre caps and bolt heads. They're VERY good. The plus point about them is that the et is 35, as opposed to 45 of the genuine's. You can colour code the centres quite easily by masking up the lip, there's a very defined groove which would help lots.
JPR_polo_gti
