Tight clutch?
morrismen
Tight clutch?
Post by morrismen »
Oh err Mrs... :P
Well, I looked further into the dynamics and mechanics of the Polo GTI manual (non-hydraulic) clutch and finally I have found the cause of the judder under foot and the apparent tightness of the clutch when the pedal is depressed.
The issue is not at the pedal end - its at the locking nuts end! :o
When a new clutch cable is fitted or it's re-tightened (after Pedal Box refit), the tightening of the lock nuts twists the cable inside the cable shroud - this causes it to stick, graunch and give the clutch pedal a bad feel. :?
Here's what you need to do.
1. Loosen off the locking nuts to the end of the cable end (engine side)
2. Push down lightly and turn the Black tippee shaped stopper underneath the nuts at least twice anti-clockwise. You will eventually feel the inner metal cable turning, and hear it turn at the pedal end too.
3. Push down the Black tippee shaped stopper so it cannot move under the nuts.
4. Pull the cable end towards you to draw up the slack.
5. With the Black tippee shaped stopper held in place, turn the locking nuts down with your fingers, whilst pulling the cable tightly towards you - important.
6. When the first 13mm nut is down, the spring will need to compress fully.
7. Hold the cable end and wind off the 13mm nut one turn with your fingers. The spring will still be quite compressed, but this does not matter.
8. Tighten up the 10mm lock nut onto the 13mm nut to lock it.
9. Start the engine. Note the pedal will move only very slightly downwards underfoot when you rest your foot on it.
10. Check the clutch operation as it's fully depressed.
If you follow this, your clutch will now be smooth all the way to the floor like mine, no graunching, no sticking, no judder; just smooth operation to the floor and back again :D
That'll give you all something to do over the weekend won't it :wink:
live2themaxuk
Post by live2themaxuk »
you LEGEND, if this fixes my prob ill be a happy man. I just had my car booked in to have this looked at at the same time as pedal box.
My car recentley had a new clutch cable. Felt really nice then got worse again....... could be same prob as you.
ALso it feels all juddery and notchy at the top of the travel, catching, then letting go catching then letting go making for a juddery take off.
Ill try this tomorrow and see if it helps.
Same probs as you?
morrismen
Yeah!
Post by morrismen »
Same problems, except my clutch was juddery at the bottom until I adjusted it up further to the top so the judder was removed. Make sure the spring is fairly compressed as it has no effect, and with the adjustment you need to remove the sticking and juddering, you need to compress it anyway. :wink: It's the 'unwinding' of the clutch cable (inside) using the black plastic tippee stopper that's as important to untwist it. Good Luck - I hope it fixes it like it has mine :D
Polo_Gio
Post by Polo_Gio »
Long time since this post was written but i have the same problem now......anyone got pics and did it def fix your prob
cheers
Gio
nickpolo
Post by nickpolo »
yeh, pics and more detail would be good, my clutch is very 'graunchy' and creaky at the mo
ta
182_blue
Post by 182_blue »
abyone else tried this ?
Si_GTi
Moderator
Post by Si_GTi »
182_blue wrote:abyone else tried this ?
I haven't, but judging by the action of my clutch today I might get it looked at and adjusted as above! I've got the creaking mentioned in other topics where after a few miles the pedal creaks on depression :?
nickpolo
Post by nickpolo »
i get that all the time si
dubpolo
Sponsor
Post by dubpolo »
does the cluch auto adjust tenshion or can you tighten it? think mine is strched and aint full disengaging(sp)
Si_GTi
Moderator
Post by Si_GTi »
dubpolo wrote:does the cluch auto adjust tenshion or can you tighten it? think mine is strched and aint full disengaging(sp)
Exactly what was happening to mine up until recently. Had it adjusted by the guy who fitted it. You can adjust it manually, yes, but I've no idea how its done :oops:
dubpolo
Sponsor
Post by dubpolo »
thanks dude! im going to take it to awesome GTI on wednesday and get them to show me!
