Basically I looked at the three plugs that go into the car from the door and wondered if anyone has access to a wiring diagram, or better still if anyone could have a look? I would be VERY grateful! I would guess it's just a matter of popping off the rubber and unclipping the plugs. (Drivers side)
This is what my plugs contain so I guess someone WITH the door lights would have two extra wires somewhere. And I'm hoping the the plug connector on the my car has the extra 2 metal pins.
TOP PLUG: has 5 spaces (holes) but only 2 are used. GREEN AND BROWN (PIN 3) and RED AND GREEN (pin 4) are used.
MIDDLE PLUG: has 21 spaces and 9 are unused (too many different colours to write down, but hope this will help)
BOTTOM PLUG: has 4 spaces and 2 are unused. BROWN (pin 1) and RED and YELLOW (pin 2) are used.
Here's a pic it's not clear but hope it does something.
