1) "When the car is locked and you unlock it, within 30 seconds or so it will re lock itself, unless you open the drivers door, then it stays unlocked".
Correct, our 9n does this
2) "However, I have found the auto lock feature will lock the doors even if you open and close the passenger door or leave it open".
Something wrong here - once either door or the boot is opened and/or closed again our car will not lock itself again.
3) "Second is if the car is locked and you press the lock button on the remote fob it turns off the double locking, and if you press it again it turns double locking back on"
Our 9n does this but I'm not quite sure why!
You might also want to check the auto boot locking:
Unlock the boot only with the middle button on the zapper. Check that only the boot is unlocked.
Open the boot, pretend that you are putting the shopping in.
Close the boot making ABSOLUTELY sure that you have the key in your hand and haven't dropped it into the boot
The boot should now re-lock itself while you pretend to take the shopping trolley back.
Also if you unlock the boot with the zapper and don't open it the car should re-lock itself.
I should think that if you can't resolve number 2 then you need the car plugging into a VW diagnostic computer - this should be a warranty job.
Just another thought - have you added anything to the interior light/locking circuits which might be confusing the car's brain?
