rooboy wrote:Very nice, still a bit high though!!!
I'm just wondering, because I got this coment before. Is this really true? Are you serious I mean?
I am not angry or anything, just curious
You have to know actually that the carter(oil pan? ) is 3cms(1,5inch) away from the ground.
Diesel he...
When I got home from that meeting(worthersee in Austria) the car was screwed down another cm, so that means that the oil pan is only 2cms
from the ground. (Measured when standing still, when you drive the car comes lower he)
Can you imagine how many times my inox-protection-shield hits the ground per day? And not just the harmless scraping of the tarmac(only scatches the oilpan-protection a bit); I drive rather slow on bad roads though so it's still do-able for me..
To be honest I would like the car to be lower, but it is impossible to drive in then.. Plus you have the fact that the kw suspension is at its lowest at the back. I even took out the screwsystem, which means that the car is even 3cms lower than possible with the kw suspension..
