GTI Differencies???
ModifiedMadness
- Sponsor
ModifiedMadness
- Sponsor
air con only provides cold air doesnt it?tomo87 wrote:ye i think that is the only diff realy, and isnt there a diff between air con and climate control??
i wouldnt touch one without headlight washers unless i knew for a fact they had been smoothed out. and dont you have to have washers for xenons?
if there are no washers, theres no xenons
i hate them i turn my lights off to wash my window so i dont skank on my bonnet loltomo87 wrote:i think they are well scary!
Redline
- Sponsor
- Drives: BMW 128ti
The difference between air-con and climate control, is that climate control does what the name implies. It actually monitors the interior temperature etc, and adjusts the cooling/heating to keep it to the temperature you set.GTILass wrote:air con only provides cold air doesnt it?
Manual air-con means you have to choose whether to make the temperature hotter or colder to suit your preference.
And as stated above, just because it doesn't have washers, does not mean it won't have xenons.
the GTI's with xenons had the washers, from what everyones said xenons were standard on the GTI's.... i checked with VW regarding them as i didnt think they worked when i bough the car........turns out i just didnt know 'how' they workedRedline wrote:The difference between air-con and climate control, is that climate control does what the name implies. It actually monitors the interior temperature etc, and adjusts the cooling/heating to keep it to the temperature you set.GTILass wrote:air con only provides cold air doesnt it?
ModifiedMadness
- Sponsor
