[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Front Aero Wipers - UK-POLOS.NET - THE VW Polo Forum
If you get the flat blade upgrades from www.wiperblades.co.uk then they're a direct replacement for the ones you've got, I've got them and so have a few others on here.
ModifiedMadness wrote:If you get the flat blade upgrades from www.wiperblades.co.uk then they're a direct replacement for the ones you've got, I've got them and so have a few others on here.
They're really good.
Yeah I did hear quite a bit about them and was tempted but thought I would get some more info
You can get them from VAG parts as a full kit. Are these any good/better?
The ones at wiperblades.co.uk seem quite cheap as an upgrade
EDIT: The ones I would need would be "Aerotwin Retrofit FLAT WIPER BLADE UPGRADE TWIN PACK 2 x 475mm" wouldnt they?
I bought the valeo ones from a motor factor round here. I gave them the parrt number i got off wiperblades.co.uk. They were £6.75 each. The kit from vag parts is a full kit including arms. They do look a bit better but cost so much more. Mine look like this...
These are a vast improvement on the standard 6N2 ones, as said i got mine from wiperblades.co.uk Super fast service i got, and just a quick min to put on, i dont see the need in the whole arm thing myself !
Ian_R wrote:These are a vast improvement on the standard 6N2 ones, as said i got mine from wiperblades.co.uk Super fast service i got, and just a quick min to put on, i dont see the need in the whole arm thing myself !
I think it would be a lot easier for me to get the ones from wiperblades.co.uk
Looking at the pics, they look quite good and several people have raved about them on here
