Interior lights
tinny_uk_75
Interior lights
Post by tinny_uk_75 »
Hi
New here and just got a Polo.
I have no lights on the heater controls and the dash lights appear very dim. Even when I turn up to full illumination with the dimmer.
I think the bulbs have gone esp in the dash - two at bottom appear to work but no others. Is this normal or have the bulbs indeed gone then is it a pain to get at them or is it simple?
An old Y plate ford fiesta I had really dim dash light and whan I took dash apart there were big blue plastic thingys over them, threw them in bin and I could see dash. - Is there a similar thing with the Polo?
tinny_uk_75
Can anyone help?
alexperkins
Site Admin
Post by alexperkins »
Could be a fuse although you say two are working so its most likely blown bulbs. Check the fuses anyway and the wiring - may be badly earthed.
Its best to replace them with LEDs if you have to put new ones in.
dragon_green
Post by dragon_green »
with the heater bulbs, sometimes there's a loose connection. I fixed mine by hitting the panel with an open palm. Sounds like a pikey fix, but it did the job!
