on the new GTi, you get a compressor and seleant, any ideas how to use it, i understand that you remove the valve on your broken tyre sqeeze the seleant in and then blow the tyre up but how do you remove the valve?
if anyone has a site or pictures on doing this please link.
Tyre seleant?
In the instructions Book 3.2 Page 76 It talks about screwing the the valve insert into the tyre valve using the valve insert extractor.
I would suggest that you use the valve insert extractor (item 1 on Fig 28 ) to remove it in the first place
Hope that helps
I asked about spare tyre when I was ordering mine and Salesman thought it would be quite expensive to fit.... but when I picked it up. Under the carpet mat was a spare tyre. Result!! Salesman just looked blankly. So doubly bit of result
Hope that helps
- KennyPOLO_Gti
- Platinum Member
