im the guy! i fitted a set of these to mine just after christmas!!
its pretty straight forward really!!
the fronts are a straight swap!!
the back is a little more challenging the backrests are hard to get out as the clips holding them in are really hard to get out! but once you have got those out the back rests go straight in!
the only bit that needs modifying is the actual seat bit in the back! the clips that attach them are slightly different on the ibiza they are actual brakcets that bolt to the car floor! and in the polo its just pins that clip into brackets! what i did was simply chop off the brackets with a small hacksaw and they clip in fine!!
they look amazing and are so comfy!!
are you the same Polo GTi off Demon Vw??
and heres wat they look like in the car
