badge removal
badge removal
removed the polo lettering but can still see were it was stuck on. is t-cut the best thing to use to remove the lettering outline?
partridge88
If you are getting white marks underneath them... I know a little trick which MAY help..
On the corsa c forum, people were getting white lines underneath where they had taken the side rub strips off, on some older cars that is sort of 2000-2003.
If you are getting white marks where your badges were t-cut etc wont work.
The white is caused by water getting into the laquer.
Nick your mums / sisters / gf's hairdyer or get a heatgun, and slowly heat up the paint where the white marks are.
DO NOT DO IT TOO CLOSE OR ON TOO HOT A SETTING AS THE PAINT WILL BUBBLE! But I did this on my corsa and it worked a treat.
