Couple of Mk2 problems.......
Chat about your MKI or MKII Polo (86 and 86F)
The G Man
Post by The G Man »
First one... speedo...
Original one was sticking so I've replaced with Coupe ones but the speedos not been right since.
Have got the one with 1578 on the dial so I know they are a straight swap but the speedo squeeks and is showing the wrong speed when I get past about 30mph. The pointer wobbles irratically and sometimes it is worse than at other times. ie: This morning I was doing about 40mph but the speedo was wavering around 60-70mph mark!!!!
Anyone know what's wrong? Is the speedo faulty and if so, is there a way to fix it? I've got a few speedos so I could use the bits from them if need be (but only one with 1578 on - not including the original that I removed of course but that doesn't have a trip counter on)
Secondly, have a bit of a problem with the rear suspension and need to know if it will pass its next MOT. If not, I'll need to get this done before it's next due. I noticed that when I was getting in and out of the car that it was making a slight noise (grinding) from the back.
On checking the suspension I've found that the rubber gaters inside the springs on the back suspension (that cover the shock absorbers) have corroded and are both splitting (the one on the driver side has split all around the bottom and the plastic tube attatched to it has come detatched and dropped down so I can see the shiny bar leading into the shock absorber. I'm assuming that these rubber gaters serve some sort of purpose (possibly stopping water from getting onto the shiny bar and into the absorber and this is why it's making a grinding noise??)
Is it hard to replace the shock absorbers if this needs doing?
TIA
Phoenix
Post by Phoenix »
back shockers are a doddle to change
1. get in the back and undo the nut off the top of the strut
2. jack up the car on the back side your on and undo the 17 or 19mm bolt on the bottom.
WARNING : the spring uses the car to compress again so when you jack the car up the spring will open.
just watch when you put the new one on, put it in the bottom first then it takes some clever lowering of the jack to get the strut through the top, into the car.
best thing is all can be done with wheel on (well i never took them off)
Shugeed
yeah
Post by Shugeed »
the grinding noise could be you handbrake needing adjusted, because when you get out the car the suspension rises a little, and as the the suspension rised the wheels turn ever so slightly, and if the hand brake isn't gripping right it will make a grinding noise, i have the same problem with my MK2 polo.
