steering wheel
polo_dude
steering wheel
Post by polo_dude »
i 'm worried to drive the car incase my steering wheel comes off :shock: everytime i turn the wheel it makes a scrathing noise i've had a gd look around buh i dont seem to see anything that could be making that noise i've left the car on it's own jst too scared to ride it incase anything may happen :( ..does any any have a clue what i can do or what the problem is ??
alexperkins
Site Admin
Post by alexperkins »
Does it sound like its grinding against grit/sand
Tis a common problem. Happens to mine every so often and shantybeater had it the other day too. Just spray a wolloping of WD40 around the joint of the steering wheel - if you can, take the surround cover off and give it a good ol' blast - will remove all the grit and it should sound sweet again :D
pip_polo
Post by pip_polo »
i had it, then just went again. it just sounds like a bit of dirt.
nothing to bad
david burton
Post by david burton »
happened in my old one, just some dirt as the people above have mentioned. blast it with air or just blow into it and adjust the wheel up and down.
polo_dude
Post by polo_dude »
thanks guys i was reli crapping myself there thought it would cost me a bomb...thanks for all ur help!! :D :D
Polo_dude
JoeG07
Post by JoeG07 »
yeh i had this, theres two metal discs that rub against each other at the back coz obv u cnt have wires into the steering wheel, and bit of wd40 does the job like they said
