[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Headgasket Change - UK-POLOS.NET - THE VW Polo Forum
I've never heard of a Polo GTI needing the head gasket done before, factorying in you would be better to change the timing belt/tensioners and water pump when the heads off I would have thought you would be looking at around £500.
max, my 1.0 is on 73thousand and still going good mate, i wouldnt touch it until you need to, theres a saying 'if it aint broke dont fix it'! spend your money on something else mate
