strong petrol smell from exhaust all the time mk4 1.4
shauni boi
Post by shauni boi »
im have noticed recently im getting a petrol smell comin out the exhaust it smells like the burnt smell you get from the catalyst usesally i onli get it wen im flooring it but now im getting alll the time i can smell it as soon as i open the window its 100% cummin from the exhuast. any reason y?
things i have replaced
throttle body
02 sensor
temp sensor
all these parts were changed over 6 months ago.
warrmr
Post by warrmr »
engine breather,
have a look under your airbox there should be a pipe comeing from the back of the engine towards to top. and it should go inot the bottom of the airbox. check that if its not that then i havent a clue..
Bepe
Post by Bepe »
is there any signs of leakages? obvious things?
bstardchild
Moderator
Re: strong petrol smell from exhaust all the time mk4 1.4
Post by bstardchild »
shauni boi wrote:im have noticed recently im getting a petrol smell comin out the exhaust it smells like the burnt smell you get from the catalyst usesally i onli get it wen im flooring it but now im getting alll the time i can smell it as soon as i open the window its 100% cummin from the exhuast. any reason y?
throttle body
02 sensor
temp sensor
Silly question but whats your mpg like?
shauni boi
my mpg is not good im only getting just under 30 mpg!
MintySE
Post by MintySE »
when mine was like that i found it was the fuel lines seaping out @ the top
never got chance 2 replace them unfortunatly
Shabazmo
Post by Shabazmo »
I have a strong small of petrol on my 1.6ltr AEE engine polo 1997. Checked the breather pipe and found it had come off the air filter housing. Hope this cures the problem.
BIG4244
Post by BIG4244 »
my 1.4 AEE has worn piston rings, causing the combustion gasses pass the rings and pressurise the block, which causes a strong smell of petrol/oil/exhaust coming from the crankcase breather, and if the oil seperator becomes blocked itl just start releasing the gasses to atmospher, hence the smeel, well that was in my case anyway
shauni boi
sorry guys but the problem was sorted long time ago but i jst forgot to put it on on the fourm.
whai i did was replaced the lambda sensor which solved the problem and it improved the mpg aswell.
Shabazmo
Post by Shabazmo »
Just to confirm that I cured the problem when I re-attached trhe bottom pipe to the air filter housing.
JarnoVWPolo6N
Post by JarnoVWPolo6N »
BIG4244 wrote:my 1.4 AEE has worn piston rings, causing the combustion gasses pass the rings and pressurise the block, which causes a strong smell of petrol/oil/exhaust coming from the crankcase breather, and if the oil seperator becomes blocked itl just start releasing the gasses to atmospher, hence the smeel, well that was in my case anyway
You really need to watch out for this!!! When experiencing more "blow-by" then normal (blow-by is air-fuel mixture entering the carnkcase slipping past the piston rings) then the oil get's "lean" due to the fuel being added to it. When the oil get's too "lean" it doesn't lubricated good enough as it was intended, making your bearings wear out far faster then supposed! With whatever kind of trouble that can arise from that :(
