Throttle Body cleaning help/advice
shantybeater
Post by shantybeater »
im up for that too, been trying to get rid of a metallic whirring sound for ages!
Mouse_GTI
Post by Mouse_GTI »
Anyone post up a DIY guide?
alexperkins
Site Admin
Post by alexperkins »
No need - its on the back of the can :P
Rupy
Post by Rupy »
one of you can do mine...i'm too busy at the min! :lol:
Free beer to whoever does it :wink: :lol:
Mouse_GTI
Post by Mouse_GTI »
I'm gonna look in Halfrauds for carb cleaner and some BMC filter cleaner, then put up a double DIY guide
Tim_GTi
Post Whore
Post by Tim_GTi »
sounds good mouse! (just dropping a post so i can keep track of the progress on my emails haha!!)
Mouse_GTI
Post by Mouse_GTI »
It was total easy but I'll still post up some pics when I get home. It was quite dirty. Car doesn't feel any different, maybe just a tiny tiny bit more smooth
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
the throttle body being cleaned is so simple that it hardly even needs a guide. Here is one i wrote for someone ages ago which they understood perfectly:
take off your air box / induction kit
the throttle body is the metal circle on the right that opens with a butterfly
spray carb cleaner on a cloth and wipe it and spray carb cleaner in the guts of it, get in to fiddly bits with cotton buds.
if you reach round the back you can find the cable which opens and closes the throttle body, makes it easier to clean
you might need to reset your ecu if your idling too high or over revving after doing this.
I just drove ~100 miles and my idle sorted itself out without an ECU reset
Tim_GTi
Post Whore
Post by Tim_GTi »
loud wrote:the throttle body being cleaned is so simple that it hardly even needs a guide. Here is one i wrote for someone ages ago which they understood perfectly:
So is all this done with the car switched off?
Mouse_GTI
Post by Mouse_GTI »
Clean it first as normal then switch it on and get someone to give it blasts of throttle. Keeping the throttle constant won't open the valve
loud
Post by loud »
yea it was done with the car switched off cos u can grab the cable that opens the butterfly valve through the back so holds it open much better than someone hammering on the throttle non-stop
alexperkins
Site Admin
you must remember to not flood the carb with the throttle body open with the cleaner tho - or the car wont start!!!!
Mouse_GTI
Post by Mouse_GTI »
You just have to give it little bursts. My car cut out twice but was ok again afterwards
Bepe
Post by Bepe »
alexperkins wrote:you must remember to not flood the carb with the throttle body open with the cleaner tho - or the car wont start!!!!
carb? i didnt think these polos had carbs........iam lost :shock:
alexperkins
Site Admin
Whatever throttle body :P meh!
