My Gti has a strange knocking....
Rupy
Post by Rupy »
Hey guys...need advice.
I've spoke to a mate who's good with lowered cars and he said this sounds wrong.
I bought the car with a knocking that occurs when i turn the wheel left/right towards full lock. Before i bought it dave had the top mounts replaced...thats when this knocking started. Thought this might go away over time as the mounts settle in. Does this sound right?
What else could it be? car is really low on coilovers.
Rupy
Rupy
Post by Rupy »
41 views and not one reply :cry:
shantybeater
Post by shantybeater »
hey mate, i cant say i noticed it around corners in particular but my car started making a knocking noise when I went over bumps, turned out to be the drop links.
1der
Post by 1der »
mine knocks after fitting coilovers. thought it was just common after fitting them?
DanDiesel
Sponsor
Post by DanDiesel »
could be the anti roll bar knocking on the driveshaft mate! i've had this on my ibiza, sorted it with a new set of droplinks to raise the arb a tad. i'd get that checked out first because it is quite common on lowered cars!
the noise hasn't gone so it turns out that even tho the arb was touching the driveshaft, it wasn't creating the knocking.
the mystery goes on! well over a year now! :roll:
Bepe
Post by Bepe »
its a common thing mate, mine does it and iam sure everyones does it!
Si_GTi
Moderator
Post by Si_GTi »
Mine used to knock when turning to the right and towards full lock. But after a few weeks it stopped and hasn't come back since :)
Bepe
Post by Bepe »
i will be honest with you, i think all it is, is the springs are under alot of stress of being turned!
Tetsuo_83
Re: My Gti has a strange knocking....
Post by Tetsuo_83 »
Sorry I didnt spot this thread on here... no point in continuing to reply over there (since im the only one who replied, lol).
Tetsuo on Club Polo wrote:Either your CV is gone or somethings knocking against the drive shaft.
Edit: just thinking about it now... when i bought mine it had a similar noise on full lock. Turned out the mechanic didnt tighten the whell bolts properly after he changed my Clutch. shock.gif true story.... go check your bolts!
Rupy on Club Polo wrote:Checked the bolts straight away when i got the car...all good.
There's a thread on UK-polos.net where a few people have had a knocking thats the spring in thier coilovers?
Its both left and right..
I know some people will disagree with me here... but it aint normal, get it checked.
I would have said your CV joint was gone until you said both sides... more than likely your driveshaft knocking.
Rupy
Post by Rupy »
But would a drive shaft knock even if i was stationary?
J-GTi
Post by J-GTi »
What brand of coilies do you have Rupy?
My FK's do it !
1der
Post by 1der »
iv got fks too
Arnoldo
Post by Arnoldo »
I get a sound which can only be described as metal scrapping when I do full lock slowly. Think its either the springs or the top mounts movin a little. Is this the same thing as above? It doesnt happen when im driving tho :S
david burton
Post by david burton »
I would say that perhaps the spring is staying still when you turn the wheel, and knocks when it finally releases. I had springs that did this once. try greasing up the top and bottom bits where the spring sits, see if it helps.
Rupy
Post by Rupy »
It's on FK highsports.
Dave said that it never happened with the old top mounts....
It'll not be too tight or anything will it? The idea of the spring just pinging sounds plausible.
