interior light
yoshi
interior light
Post by yoshi »
well, my heater and fan lights have stopped working for no apparent reason. All my other lights work i.e stereo, dials eg. Anyone got any ideas what it could be? fuse ? cheers
matty2767
Post by matty2767 »
try the fuse they may be on the same circuit. it is to the right of the steering wheel. you have to pull the cover off and the card inside will tell you whats what.
yoshi
Post by yoshi »
oh thanks mate, cars pee'in me right off at the moment !
Zero-Tolerance
Post by Zero-Tolerance »
same happened to me a while back, pull the center dial out and behind it is a bulb that you will need to replace, to get to the bulb you will need a thin pair of pliers
prawny
Post by prawny »
this has just happened to me, is this the likely cause?
Si_GTi
Moderator
Post by Si_GTi »
prawny wrote:this has just happened to me, is this the likely cause?
Probably. Bulb was goosed when mine stopped working. Blimey, that's going back some (2003)! :lol:
