KennyG
Posts: 136 Joined: Sat May 21, 2005 10:45 am
Post
by KennyG » Wed Aug 22, 2007 8:36 pm
That's s**t dude!! My water pump has just gone so gonna have to get that and the timing belt done, just a few months after gettin the gearbox and clutch done!!! Loosing faith in the Polo big style!!!
sorted
Posts: 794 Joined: Tue Apr 13, 2004 4:34 pm
Post
by sorted » Mon Aug 27, 2007 11:43 am
The rebuild is on.
Will get some progress pictures
Had the car 4 months , and i have some amount of repair photos LOL
Si_GTi
Moderator
Posts: 5020 Joined: Thu Apr 08, 2004 1:14 pm
Post
by Si_GTi » Mon Aug 27, 2007 1:19 pm
What a ball ache! You have a pretty assistant though
Not planning any strengthened or modified internals whilst your at the rebuild - lightened flywheel for example?
Best of luck with the rebuild
sorted
Post
by sorted » Mon Aug 27, 2007 10:14 pm
pARTS ARE HERE
First four bent valves
First Four bent valves - side view
The head at the start:
Valve Springs
8 bent as a row of pink tents valves
8 NEW VALVES
All Lap'd in
Before sanding the head :
A row of bent valves :
All lapped in:
Working hard at it
Sanding the head
Parts LOL
Sanded and Cleaned head:
Valves were really hard to get out, so got 8 out and 8 lapd in. The other 8 are getting done tomorro. Ran out of time - 2nite took from 5pm to half 9!!
Job done so far.
Neildo
gazmangti
Posts: 75 Joined: Thu May 10, 2007 7:34 pm
Post
by gazmangti » Mon Aug 27, 2007 10:21 pm
Good work mate. I hate lapping valves in
. Boring job.
How hard is the cambelt to do?
Redline
Sponsor
Posts: 1641 Joined: Tue Jan 28, 2003 9:43 pm
Drives: BMW 128ti
Post
by Redline » Mon Aug 27, 2007 10:38 pm
This has just served as a big reminder that my cambelt change is overdue!
sorted
Post
by sorted » Mon Aug 27, 2007 10:57 pm
Callum
Posts: 121 Joined: Tue Oct 11, 2005 1:22 pm
Post
by Callum » Tue Aug 28, 2007 1:03 pm
Ahhh, the trusty bent valve trick!
Lapping in the new valves is the worse bit, I should know as it happend twice in my car!!
Make sure you torque the tensioner to only 20nm, I know it's awkward to get to, but it will fail if you don't!!
The actual job it self is pretty easy, just time consuming....
sorted
Post
by sorted » Wed Aug 29, 2007 12:35 am
sorted
Post
by sorted » Fri Aug 31, 2007 10:09 am
Wed Nights Work
Got the cam box bolt on as well - just never got a photo. Thur night never done any work, hopefully tonight finish of a few wee bits , then get the new water pump and timing done.
Neildo
sorted
Post
by sorted » Tue Oct 16, 2007 8:43 pm
5th Gear DEEEEEEEEEEEED
Gear Selector marked
Somethings ive been doing while the gearbox was away getting fixed ....
Tinted with no laquer!
Never done any bodywork stuff before but gave it a try and see how it goes
Neildo
1der
Posts: 604 Joined: Fri Aug 11, 2006 2:41 pm
Post
by 1der » Sat Oct 20, 2007 10:49 pm
you fibreglass the bumper wher the rubstrips were?
