coilovers
Tim_GTi
Post Whore
Post by Tim_GTi »
h4r1s wrote:
dubpolo wrote:5 bolts per strut for the front..... :roll: :roll: ...... really aint that hard :P
exactly all you need is a couple of different size spanners :wink:
yeh this is exactly what i hear from alot of people!!! I would just be really grateful if sum1 cared to make a tutorial so I know exactly what to do
shantybeater
Post by shantybeater »
not to mention a spring compressor?
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
shantybeater wrote:not to mention a spring compressor?
don't need spring compressors if you are replacing the whole strut and spring, it's only when you are changing springs over, or you want to use your original top mounts that you will need spring compressors
Tim_GTi
Post Whore
Post by Tim_GTi »
is it worth replacing the top mounts when getting coilovers? if so how much do they cost and with what; same but newer or aftermarket?
h4r1s
Post by h4r1s »
CymruPolo wrote:
CymruPolo wrote:Does your camber need doing if you adjust them say about 10mm or so? I'm curently sat at 70mm but I'd like to go another 10mm.
I said ....
:lol:
I think it will mess up the camber, but only by a bit
Tim_GTi wrote:is it worth replacing the top mounts when getting coilovers? if so how much do they cost and with what; same but newer or aftermarket?
It's best to change them over, might as well while you have the chance. And i think they are about £15 from gsf
Tim_GTi
Post Whore
Post by Tim_GTi »
ok, whats gsf? is that £15 each? does that mean its not so straight forward in changing suspenson over?
bristolgeezer
Post by bristolgeezer »
had the coilovers fitted yesterday, im not 100% happy with the ride height tbh, would've liked it to be lower and the kit goes lower but its as low as it'll go at the moment without constantly rubbing :(
drivin it a bit since having it done and wow the ride is hard and bumpy lol but it handles well oh and it does rub alot too :p
heres some pics from today at eurofest :D
what do you think then?
cheers,
ash
ModifiedMadness
Sponsor
Post by ModifiedMadness »
I'm suprised it rubs loads, I don't get too much rubbing (only over some bumps and round fast corners)
I'm somewhere between 60-70mm
h4r1s
Post by h4r1s »
Well it is, i should really do a guide :roll: will definately do one when i get my car back, since i need to take one of the struts out anyway. basically you can get top mounts from eurocarparts, GSF(are similar) or the stealership and yes they are are about £15 each IIRC. And all you need to do is bolt them onto the front struts, the rear ones can be taken off without spring compressors if you don't want to replace them.
ModifiedMadness wrote:I'm suprised it rubs loads, I don't get too much rubbing (only over some bumps and round fast corners)
Same i thought it would only rub if your tyre is either inside the arch at the top (like mine) or you have wider wheels.
Car looks loads better btw, top job 8)
dubpolo
Sponsor
Post by dubpolo »
dude you can go lower without rubbing....standard wheels.....trust me 8)
BTW your car looks too much like mine :evil:
bristolgeezer
h4r1s wrote:Same i thought it would only rub if your tyre is either inside the arch at the top (like mine) or you have wider wheels.
dubpolo wrote:dude you can go lower without rubbing....standard wheels.....trust me 8)
trust it does rub alot, i dunno if its because of the tyres, they're sort of balloony, they're odd, i'll try and get a pic of what i mean,
the spot it rubs on is where the screw that holds the arch liner on to the front bumper is located, theres a bulge in the liner there.
oh and thanks guys, it does look alot better :D
Mouse_GTI
Post by Mouse_GTI »
That looks good. Bit like mine, not too low, not too high
dubpolo
Sponsor
Post by dubpolo »
Mouse_GTI wrote:That looks good. Bit like mine, not too low, not too high
you can never be too low 8)
JPR_polo_gti
Post by JPR_polo_gti »
very sexy 8)
