TT peddle mod...
tegwin
TT peddle mod...
Post by tegwin »
I saw a picture the other day of a GTI with TT peddles...they look smart!!
Where is the best place to get the peddles from?
Is it the entire peddle that you replace, or just the pad on the end?
MaxZ
Post by MaxZ »
You can get them new from either VW or Ebay.
Take your pedals off and these should slip on, the accelerator pedal tends to be bigger so will have to be glued on.
Si_GTi
Moderator
Post by Si_GTi »
You will need RHD clutch and brake pedal "rubbers" (I know, I know, they are actually metal and rubber, yes) and LHD gas rubber as this is the best fit.
Clutch and brake are a direct swap and gas just needs some double-sided sticky tape or araldite or some such to secure it. There are many many many posts about fitting if you do a search :)
Mouse_GTI
Post by Mouse_GTI »
My accelerator pedal just went straight on. No problems with it falling off at all 8)
DanDiesel
Sponsor
Post by DanDiesel »
ebay, vagparts, or just a vw dealer would be able to sort you out with a set of these.
i bought my last set from ebay for about £20!
nafeGTI
Post by nafeGTI »
I had to glue my accelerator one on, got them for about £25 from ebay
jonners_gti
Post by jonners_gti »
i'm thinkin of making this my first mod.
does everyone agree you need RHD clutch and break and LHD accelerator pedals? or does the RHD accelerator pedal fit fine too?
thanks
Tim_GTi
Post Whore
Post by Tim_GTi »
jonners_gti wrote:i'm thinkin of making this my first mod.
thanks
correct,
I have this, I used araldite (glue) on the LHD accelerator, the other two fit like a glove.
Also i'd advise getting them from www.vagparts.com, they do a good price for the set, search in the product overview> VW> polo> interior> pedal rubbers.
Or give them a ring their willing to help
nafeGTI
Post by nafeGTI »
i bought the RHD kit and had to glue the accelerator, a great simple mod tho :)
jonners_gti
thanks
correct,
yup had a look on vagparts. the LHD accelerator pedal is £1.46 cheaper than the RHD one!!
i'm guessing you have to take the current pedal rubbers off before you put these ones on?
Tim_GTi
Post Whore
Post by Tim_GTi »
yep 8)
CymruPolo
Not so new
Post by CymruPolo »
A simple but effective mod :)
nogwuy
Post by nogwuy »
r32 pedal covers also fit with persuasion, but are a bit more pricey :D the tt ones are thinner alluminium and the accelorator one bends quite easily to match the curve of the accelorator. ive got tts on the polo and have also fitted them to my previous mk2 golf 16v and mk3 golf gti with relative ease. if the rubbers are stiff to get on then drop them into a cup of boiled water for a few seconds to loosen them up :D
