power cable for sub
power cable for sub
where have you guys ran your power cables for your sub?
we had a quick look after fitting my headunit but couldnt see any gromets going from the engine bay to the inside.
oh and its on a 2001 gti btw,
thanks,
ash.
thanks,
ash.
- Tim_GTi
- Post Whore
yeh thers one behind the glovebox, if your still having problems i'll post a pic of where mine is. be careful tho cos thers a A/C water deposit hole in the passenger footwell. its the most obvoius one u can see with the big rubber pipe going thru it, DONT USE IT! all the waste will come into your footwell, past experience haha
if you could post a pic that'd be brilliant mate,Tim_GTi wrote:yeh thers one behind the glovebox, if your still having problems i'll post a pic of where mine is. be careful tho cos thers a A/C water deposit hole in the passenger footwell. its the most obvoius one u can see with the big rubber pipe going thru it, DONT USE IT! all the waste will come into your footwell, past experience haha
i tried to get the glove box out but just couldnt get it out, took out loads of screws from both passenger and drivers sides of the dash to try and free the glove box but it was only loose
![Sad :(](./images/smilies/icon_sad.gif)
its really starting to irritate me now, my subs sat in the boot doin nowt!
a local car audio specialist said they'd charge 45 quid just to run the cable through!!!!
- Sponsor
brilliant, thanks alot dude i'll have another crack at it this weekend, maybe 3rd tme lucky eh?!Tim_GTi wrote:I couldn't get the inside car shot, it involves taking a hell of alot of panels off. Its behind the glovebox, and to get to it you have to start at the steering column, and work your way across taking off each panel. Heres the pic from the engine bay, showing you whereabouts the hole is
- Tim_GTi
- Post Whore
dude that possibly the a/c drainage i was talking about!!! can you access just by reaching up in the passenger footwell?Hardcore wrote:dont think i did mine there:S:S mine was well hard to reach!! right t the bottom of the wall! but was in a similar place:S:S:S probs the same one the. i jus piercd it with a screw driver hahaha. wasnt too hard:D jus give it sum force:D
@ bristolgeezer: yeh man go for it, if your still having problems after that we'll arrange a meet if you want and i'll try help you out?
One place I found was dead easy to do.
If you look down in between the header tank and engine below where the brake lines run you will see what I can describe as a floppy dogs ear cutout in the sound proofing on the bulkhead. Lift this up and you can see a rubber grommet - feed the cable through here.
Inside the car just pull the carpet down slightly on the passenger side and hey presto, theres the cable.
Make sure you get the grommet fitted properly as you`ll hear engine noise in the car and you keep thinking there something else wrong with your car!!
Hope this helps
Hope this helps
