need brakes. what to get?
im needing new front discs and pads for my car. what does every body recommend /not recommend? thanks for any info
You need to get some G60 carries (scrappy cheap cheap) or £100 new from VAG Parts.MaxZ wrote:Neil, how much is a full conversion for the G60 brakes? Also how quick is it to change everything over?
This guy has the full setup : http://www.scottishvag.net/phpBB3/viewt ... 15&t=20600
For the price - 130 is very good. 2*Carriers & Calipers plus the pads and disks (BTW GTI calipers are the same as G60 - so maybe just keep urs)
I dont know the guy on scottish vag - just seen it the other day.
To change the carriers - 2 bolts. While you have the GTi ones of u fit the new disks - so not longer than fitting new disks and pads really.
Redline
- Sponsor
- Drives: BMW 128ti
As above, the G60 conversion is very easy to do.
Took me not very long at all, and that included fitting new discs and pads at the same time.
I used the guide from here: http://forums.clublupo.co.uk/index.php?showtopic=12689
mk4 glx 1.6
ModifiedMadness
- Sponsor
What's the biggest disc and caliper combo that'll fit with the standard wheels?
I was wondering if something like this would fit?
Caliper - http://www.apracing.com/roadcar/caliper ... ily=CP5100
Disc - CP4348-894/5RD, Ø295 x 25mm, Drilled, 30 Vane.
Pad - http://www.apracing.com/car/brakepad/da ... =CP2340D51
oscar olop gti
- h4r1s
- Platinum Member
- Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
So what would i need? (i am assuming the se 16v calipers are the same as gti ones) g60 carriers, pads and discs? will probably give it a go after winter, but just need to find out a price as my discs and pads need changing anyway. oh and will they fit under 14" wheels?
Edit: had a look for g60 discs and they are £280
i am supposed to be looking at the 280mm ones aren't I
+ carriers £100 + pads £80 = a total of £340 from venom motorsport without carriers
Thanks,
Haris
Thanks,
Haris
