low boost pressure? found problem... help!
david burton
how much as an exchange? the guy at the place where I went says he can get a bosch one for trade price for me (works out about £50).
I might try to swap out a sensor for another car's sensor..... if I can find one! no point in doing the MAF if it's not actually the problem.
anyone got a 9N 100 TDI, and fancies helping me out for 30 mins?
david burton
yeah, a cursory glance and squeeze of all the pipes I could get to.
I've had a thought that perhaps there's a small crack that only opens up under heavy pressure.
any ideas?
It's still very driveable if a little frustrating, so I wonder if the best procedure (and cheapest), is to wait until the problem is more noticeable and easier to diagnose.
I've heard it could also be an "N75" or something.....
any ideas?
most leaks i have found are the pipework from turbo to the intercooler as they get the intial whack of boostdavid burton wrote:yeah, a cursory glance and squeeze of all the pipes I could get to.
any ideas?
i use a similar ( homemade) bit of kit like this to check for boost leaks=
http://www.modshack.info/Pressure.htm
david burton
chris4500uk
david burton
thanks for this, might ring around and see if anyone has once locally.ceedubya wrote:most leaks i have found are the pipework from turbo to the intercooler as they get the intial whack of boostdavid burton wrote:yeah, a cursory glance and squeeze of all the pipes I could get to.
any ideas?
out of interest, am I damaging anything by running with it? I wonder if it's worth me waiting for the problem to become more noticeable.
david burton
david burton
david burton
I think I've found the issue here after a thorough root in the engine bay.
The cyan dotted line is a pipe leading to the turbo, but for some reason the bloody thing is routed between the air intake and the EGR pipe from the exhaust. Hot pipe = burnt pipe.
And pipe:
how easy is this to change? it looks like the pipe going to the control unit is glued / integral to the unit? should this really be routed here?
and would a break / defect in this pipe cause the symptoms?
And pipe:
david burton
