daa709
Posts: 412 Joined: Sun May 20, 2007 6:40 pm
Post
by daa709 » Tue Jun 19, 2007 7:14 pm
Hello,
Does anyone know anything about converting the rear drums to disks?
Is it hard to do? Would I just need the original disks and calipers? Or is it more complicated?
Thanks!
Jeff GTi
Posts: 1789 Joined: Sat Jan 06, 2007 1:54 pm
Post
by Jeff GTi » Tue Jun 19, 2007 7:40 pm
its more complicated than that mate im affraid
you will need a full rear beam already with the disks and calipers, different setup for the handbrake, brake bias's etc
its a decent sized job, but can be done if you had the money or knowledge
daa709
Post
by daa709 » Tue Jun 19, 2007 10:27 pm
Sounds evil..
I'll give vagparts a go see if they know what I need, and how much it would cost!
Tbh, the rear drums are s**t (they even squeak when coming up to lights sometimes), so i'd rather replace them.
GU!NN3SS
Posts: 35 Joined: Tue Jul 03, 2007 2:59 pm
Post
by GU!NN3SS » Wed Nov 14, 2007 3:06 pm
How did you get on with this? (if you did it)
andy947
Posts: 243 Joined: Sun Feb 05, 2006 9:28 pm
Post
by andy947 » Wed Nov 14, 2007 4:05 pm
Drums are pretty efficient when working properly.
You will see no benefit from swapping to disc other than looks - if the brakes are squeeking overhaul them, if you cant do that, you cant do a disc swap.
alexperkins
Site Admin
Posts: 14866 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Wed Nov 14, 2007 4:28 pm
GU!NN3SS wrote: How did you get on with this? (if you did it)
Ive nearly got all the parts to do mine. Just need the Caliper setup. Got the stubs, bearings, discs, pads and cables plus new speed sensors hehe
GU!NN3SS
Post
by GU!NN3SS » Fri Nov 16, 2007 9:29 am
hmm disks do look soooo much better though! and im due to change the drums and shoes anyway! decisions decisions!
alexperkins
Site Admin
Post
by alexperkins » Fri Nov 16, 2007 9:46 am
Your due to change the drums
how on earth did you wear them out!?
GU!NN3SS
Post
by GU!NN3SS » Fri Nov 16, 2007 9:55 am
No idea! Just came up on the service that they were due for a change!
Wouldnt be surprised if it was just stealership tactics!
daa709
Post
by daa709 » Sat Nov 17, 2007 9:36 pm
Na I didn't do it in the end, looked up the parts and got majorly confused. I dont mind doing it, but if someone points me in the right direction i'll be sorted.
One day!
