GTI BOX- AAARRRRRHHHH!!!!-NOW WITH PICS!!
mk5coz
Post by mk5coz »
dubbprince wrote:REALLY wasn't expecting this...but replaced the seal only to find a small 5mm hole inside the gearbox casing and a hairline crack!!
Looks like one of the gears inside has hit the inside of the casing and creating a fracture.
Gonna definately need a rebuild AND a new casing...BUT...
can anyone tell me if all mk5 and mk4 cases are the same?? so i can change over the gears inside my GTI box into another case?! :wink:
you see i told you to look at the casing common vw problem find some one who does alloy welding and get it repaired.
dubbprince
Post by dubbprince »
That was my next course of action- find an alloy welder...
Hopefully i don't need to buy a new case, but someone on clubpolo has mentioned that all mk5's share the same front bell housing case...if they do for definate! then i'm good to go... :wink:
Does anyone have gear ratio differences between different mk5 boxes?
