neilw. thanks
Are the powerflex bushes a bit on the hard side, as far as comfort is concerned?
Handling
You found them a bastard to fitneilw wrote:Yeh Its not easy thought.ticki wrote:
Did you fit it all yourself mate?
Taking the piece of metal out the fit into is easy (think thats the wishbone)
Taking the old bushes out is easy (if you destroy them)
Getting the new ones in without a press is a complete B******
Yeah the ones i eventually got had a MK4 polo down on them whcih fitted perfect, think on venom if you put a 2001 polo, regardless if gti or not etc, it comes for the MK6, So beware!womble68 wrote:guessing as well you need to get the car tracked again once you've sorted the bushes? Just sorted mine following sorting Suspension, and due to the same mistake as above on Venom's part wasn't able to fit bushes in time, i'm guessing I'll have to get it done again
