1.4 16v gearbox VS 1.6 16v gearbox ***URGENT HELP REQUIRED**
dubbprince
Post by dubbprince »
Right guys...this is pretty serious, i have no car right now...haven't done so for the past 2 weeks! and i need it back...
What i need to know is the following:
1.) what are the gear ratio differences between the two gearboxes??
2.) Are all of these mk4/mk5 boxes rod change??
3.) what is the likelyhood of me using a 1.4 16v box on my GTI engine until i can fix my GTI box...
pictures, part numbers...anything...please throw it into this topic. The sooner the better folks as i wanna get things rolling asap.
Cheers! Sanjay.
brianpologti
Post by brianpologti »
the guy that fixed my gearbox on my gti, said they all the same casing and diff, Not sure if he was feeding me a bit of bully bull, its Apsley transmissions near hemel , But he seem to no his stuff, you could call him and get some info, 01442 259982 if thats any help :lol:
dubbprince
Brian- can't thank you enough...
guys come on!! i know theres a lot of knowledgable people on here!!
Post by 8080 »
dubbprince
Thanks 8080--do you have a clearer version of the 2nd page at all??
I'm trying to compare the 1.4 16v and the 1.6 16v and i can't make out what the ratios are for the 1.4 16v.
Where did you get this info from?? I want that book!! lol. :D
dubbprince
Actually when i click on your links...it makes it clearer!!
1.4 16v 100bhp box:
1st: 3.45
2nd: 2.10
3rd: 1.45
4th: 1.10
5th: 0.89
Final drive: 3.88
1.6 16v 125bhp
1st: 3.46
2nd: 2.12
3rd: 1.44
4th: 1.09
5th: 0.89
Final drive: 3.60
So basic differences are in the final drive really!!
Would this 1.4 16v mk5 100bhp box be the same as the mk4 polo then??
Does anyone know that? :D
CymruPolo
Not so new
Post by CymruPolo »
What are the faults in these gearboxes by the way? As in what goes causing them to break.
dubbprince
something to do with either the main inner shaft bearing or the ones on the gears.
My final drive/diff are deemed useless due to a bearing exploding.
In time i'll take apart my own GTI box and try and do some investigating for you guys...
Lets just put it this way though...after speaking to an ex specialist, its not worth the cash these rebuild guys charge!! :roll:
I've now got hold of a 1.4 16v mk4 16v box...lets see what it does. :lol:
RICHARD HARPER
Post by RICHARD HARPER »
Wouldn't a 1.4 Gearbox just go pop ?
If the 1.6 Gti Gearbox can't handle power.
You may be better to keep your cash and just get the 1.6 gti box :wink:
dubbprince
shouldn't do hopefully...the 1.4 16v box is stronger...i think the bearings they used in the GTI box are the main problem with it.
I've got the box now, so i'll give it a try and see what happens...its only 25bhp more on what it's used to anyway...so shouldn't effect it as long as i don't go crazy with the speed...
The car will no longer do over 130mph...but will do about 120ish mph. :)
It should have faster acceleration i hope instead. :wink:
Getting the box back on the engine is however proving difficult!! might have to take engine out and then back in again! :roll:
Tigz
Post by Tigz »
The bearings are the same wether its a 1.6 or 1.4
The box is pretty much the same box.
The Polo GTI Box and Polo 100bhp box is the same box.
The Polo 75hp 1.4 is the same box with different ratios.
I'm using a Polo GTI engine with 75hp box in the Lupo, with GTI clutch.
Seems to work...
I think the reason why the GTI suffers so badley is because the box is not deigned to take that sort of power.
Its the same box which was found in the old Polo 60bhp 1.4!!!!
dubbprince
ohh damn!! i'm using the CWX polo mk4 16v 100bhp box in mine now...i'm hoping it'll be fine until i get my box rebuilt, i'm gonna take apart my own GTI box and see what i can do...take pics etc. Its just cold and wet right now, so might be after xmas! lol. :wink:
Tigz
Post by Tigz »
Want to sell me your knackered box?
I need one for my Polo :cry:
dubbprince
I would do...but i'm gonna give it a go to repair it myself, if i can do it then i'll start to offer a service repairing GTI boxes at half the cost companies do it! :wink:
Tigz
Post by Tigz »
The gearbox place I know charges £100 parts and £100 labour ;)
