Lowering ya car yaself guides??
tuh104
Post by tuh104 »
Just wondering if any1 had a how too, guide to lowering ya 9n yaself??
Cheers, tim.
david burton
Post by david burton »
it's not too tricky, but I suggest buying a haynes to help you out.
I also suggest soaking the whole lot (bolts) in WD40 the day before you want to do it!
it took me about 8 hours to do my car, because the front struts were seized.
all it involves is:
remove wheel
loosen 3 nuts holding top mounts
loosen clamp nut holding strut to bottom arm
remove drop link bolt from strut
remove brake hose from clips on strut
hammer bottom arm away from strut - hahah this might take forever
this will free the strut
then you'll have to remove the top mount from the strut using a spanner and a hex key on the top mount, and spring compressors will be needed to remove the spring safely.
rears are much simpler. still need spring compressors though.
poloecosse
Post by poloecosse »
you dont need spring compressors for the rear, just unblot one shockie first with the wheel still on and the car on axle stands. then put your jack under the spring pan on the other side and unbolt the second shockie. lower the jack untill the wheels touch the floor and the rear axle is down quite a bit and simply pull the springs out with ease :wink:
You can buy a strut splitting tool from Laser Tools (the tool connection) - it can be ordered through Halfords. This tool allows you to safely open up the bottom clamp/hub bit so that the strut will just (about) drop down. Its far easier to use and control than a chisel or big screwdriver etc
david burton
definitely worth getting a splitting tool. we had one but it didn't work well (was too big)
poloecosse
mine fell out no problem.
deffo get a set of spring clamps for the front tho and be careful, dont want to take ur head off :shock:
david burton
sorry, edited my post!
DAZZA_TDI
Post by DAZZA_TDI »
david burton wrote:it's not too tricky, but I suggest buying a haynes to help you out.
Had the same problem david, felt as if someone had bloody welded the strut on, took an age to free it :evil:
Dazza
tuh104
Post by tuh104 »
Had abit of a mare 2day people, spent bout 3 hours 2 try an loosen the top bolt on the strut. And it stil hasnt loosend up so iv had 2 abort tht 4 2day an i think i'll av 2 get it loosened at a garage.
Tim
david burton
you can loosen the three top mount bolts instead and the whole strut will come out - makes loosening the top bolt easier.
TDI_Burd
Post by TDI_Burd »
My boyfriend lowered my polo for me and he said the back was a lot easier than the front had no problems with the back but the front took him an hour and a half lol
claire
tuh104
Post by tuh104 »
Yeh i did take off the 3 mount bolts and took the whole strut out but the top bolt still wouldnt budge :S
