Steering Wheel Shake/Vibration
If its a vibration which can be felt through the peddles under heavy braking, (almost like the peddle is trying to kick back at you)...then you have warped disks...which IMHO is most likley for your situation...
If you have no peddle kickback under braking, then I suspect either tracking, wheel damage or bushings...
My car has vibrations, but no brake kickback, so im trying to work out where its comming from...
