HOW low can i go?? vw polo mk5
Discuss Suspension, Brakes, Wheels and Tyres
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
hi
i was just wondering how low ppl have been able to go with coilovers on a mk5 2000 1.0litre, as i had a look at the rear bumper and im worried that the wheels are gonna touch im currently running a set of 16"s,
and how low will the front go?? bearing in mind the wheels have to turn lol
-Ben-
Speedlaw
Moderator
Post by Speedlaw »
What tyres are you running?
If they're 195-40-16 you can drop it till the subframe gives off sparks, with minimal (if any) rubbing. Any larger tyre size and there's simply less room to drop it.
:wink:
polopowah
Post by polopowah »
they're 195-45-16
any ideas??
KarlM
Post by KarlM »
how low do you want to go? as Alex says you can go as low as you want on the, tyres (-60 will look the shizzle)
Speedlaw
Moderator
Post by Speedlaw »
Well if you're planning on getting coilovers anyhow, you can simply fit the parts and then drop it to your desired height.
If there's any rubbing, either change the tyres to some smaller ones or raise it up a bit.
The great thing about coilovers is the flexibility IMO, right after the superior road holding performance.
What height you aiming for? Ãœber-tief? or 'moderatly low'?
polopowah
not sure
Post by polopowah »
what ever looks sweet
prolly about -60
polo2k
Post by polo2k »
im curently in 4X4 mode and at -60mm when im in show mode (which i drive around in for about a month after) i drop it about 120mm at the front about 100 at the rear
the problem with running at -120 is that the right hand drive shaft hits the sub frame.
im using KW V2`s and 195/45/15v
polopowah
lol
Post by polopowah »
well im currently at monster-truck mode then at +20mm lol
yeah thanks for the feedback
shud have no probs then lowering it!
will let you know wen its done hopefully in about 5 weeks time
Ben
