Passenger airbag deactivation.
OctaviaRS
Post by OctaviaRS »
I can't say I recall any switches or anything in my wife's Polo so does anyone know if this is possible with vag-com?
Gra-GT
Post by Gra-GT »
Pretty sure its an optional extra when you get the car. Its usually a key hole in the top right corner of the glove box I believe. If you don't have it you'll just have a blanking plate there.
Not sure if it can be done on VAG-COM though :?
OctaviaRS
Post by OctaviaRS »
Anyone?
BeezerDiesel
Post by BeezerDiesel »
I can't see that for the rather inexpensive option the the airbag de-act is that VW would use a whole new loom when the option is specified. Basically it's just going to be a key triggered switch in the loom behind the dash somewhere, so I would think it very likely that it could be turned off via VAG COM. Try posting up on one of the forums that the VAG-COM people reply on and ask them directly for which block it would be in.
OctaviaRS
Post by OctaviaRS »
Cheers Beezer. I'll probably just drag Josh over and get him to have a shufty. He'll do anything if you feed him.
